Flywheels
  • Mark Halligan
    • 2001
    Originally posted by DJones
    Interesting read.. I have an exceptionally light 3B flywheel with a six paddle sprung driven plate and must admit i have not heard the rattle.
    I had a lightened 3B Flywheel before and never heard it either, I hear it only since I've been using the ally FW.
    Mind you even though the rattle is a bit annoying I am very happy with the ally FW and wouldn't change it. I might try a slightly heavier Gearbox oil as that may help, but if it doesn't I'll easily live with it
    Mark - Modded
    • S2_Dave
      • Aug 2005
      • 456
      Originally posted by Mark Halligan
      Linky
      http://www.corner-carvers.com/forums/sh ... hp?t=31358 What he's talking about makes sense. I think I've 'heard' it before, even on my sprung-clutch, stock flywheel 80 (mostly when pulling away from really slow corners in second gear, below maybe even 1700rpm...sounds like a box of rocks)...
      Any idea on what that concoction of oil was that the M3 owners were using?
      Thanks for the read.
      I've looked through all my current favourites and my old emails to Doug and Corey - they mention the "concoction" as an idea, but don't actual say what it was .
      EDIT: You found it whilst I was looking. That was it!!
      David
      '91 3B S2 Coupe
      • DJones
        • Jun 2005
        • 2020
        Originally posted by topsparky
        probably because it's drowned out by your wife's
        screaming
        Lol,, True..
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          Ratle is the reason wy Audi has changed the cluch disk at 200 quattro 20V turbo with modified hub wich has some small springs to damp the vibrations. The 200 flyweel lighter then 3B S2 one. The sport cluches dont have those springs.
          Hope this helps!
          All the best!
          Eugen
