ABY Hall sender position?
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    I've made a bracket to mount an ABY hall sender on my 7A head, but I need to know where exactly to put the sensor.
    Does anyone know how many degrees are between the sensor and the window in the cam wheel at TDC? Obviously I'd like to get it spot on, and I don't have an ABY head to compare.
    SS
    This might help:
    http://forums.audiworld.com/s4s6/msgs/126842.phtml
    However, I think you really need to find a ABY, AAN or ADU head to get the measurements from.
      4WD you can check out my ADU head if your in town. Give me advance warning though.
      • terrybullwon
        • Mar 2006
        • 8782
        Ah....... shocks! You should have said, i just had mine welded on yesterday using my aby one as a bench mark
        Chef
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Originally posted by UrS4boy
          This might help:
          Thanks, I know roughly where it goes, but I know how important it is to get the hall sender positioned exactly right.
          I know someone local with an ABY head, so I'll try to get there over the weekend to measure up. I thought I'd check here first, just in case someone knew off hand how to position it correctly.
          SS
          • Bruno
            • Jul 2007
            • 58
            • Country: Norway
            Good
            Keep me updated on this
            I have bought a 7A head for my rs2 and are about to do the same.
            I am searching for a ABY/ADU head to use for measureing in my cnc machine with a
            touch probe to get the exact pos of the hallsender.
            I will fabricate mounting brakets for the hallsender.
            I will public the whole machining process and measures in pictures.
            • kwlw
              • Sep 2004
              • 1025
              • Country: Lithuania
              We are starting to wait for this
              Sau
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Well I'm not sure how important the hall sender position is after reading this post. Strange, as I know the 3B one needs to be spot on for the car to start or even run right.
                Thanks to Audiman and a spare ABY head he had, I have now marked the position of the hall sender at TDC on my cam pulley, so I can transfer it to my 7A head. I just need to get some time to work on it.
                SS
                • Bruno
                  • Jul 2007
                  • 58
                  • Country: Norway
                  Hallsender bracet for 7A head
                  Now i am ready.
                  These are for sale.
                  I can make a for sale thread if there some intrest?
                  Hallgiver brakett for montering på femmer topper som ikke har hallgiver. Maskinerings tegning medfølger. KR 700 + frakt OBS dette er en ombygging jeg har gjort på min egen 7A topp. Jeg garanterer ikke at dette vil fungere på andre topper med tanke på om det er forskjell i støping eller toppen er ...
                    Now i am ready.
                    These are for sale.
                    http://forum.vwaudi-club.no/showthread.php?t=127954
                    Very nice. What price?
                    Dave F.
                    • Nace20
                      • Jul 2007
                      • 721
                      • Country: Slovenia
                      i would also need one, have an old aan head and want to move it forward
                      S2 limo
                      • Rusty
                        • 18953
                        Stu, it goes on the front under the cam pulley, if you find the most inaccessable position then that's spot on
                        If I was at work at my world leader in metrology equipment, I'm sure I could give you the coordinates to within a nat's bollock but I'm not at the mo so sorry.
                        • GTQ
                          • Jul 2008
                          • 5
                          Hall sensor mounting bracket
                          I'm intersted in getting a few of these. How to purchase/What do they cost?
                          Ben
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            No worries Andy. I got it sorted after a night with the milling machine and the pillar drill.
                            I just need to find a decent pulley now, to replace that POS ABY item.
                            SS
                            • Rusty
                              • 18953
                              There are a few adjustable ones around, be worth the extra hassle as you can retard it a bit (or advance it if going for 2 off 7A cams) and get the most out of it
