UrS6 stutter
  • quattroTurbo
    • 178
    OK. Boost leak check will also be done.
    • A1quattro
      • Jul 2006
      • 789
      Any luck finding the prob ? my rally car[rs2 20v+ecu] is also getting boost cut @1.5sh bar, weve fitted new maf,new n75 & dv ,it was doing it all the time when ever I hit 1.5sh on a rally I did last wk/end . twice the car actuly stopped it seemed as if the ecu got in a muddle ? we pulled the fuse to ecu and each time it seemed to clear until i hit full load boost again ,so i had to shift gear before peak boost to try to avoid the cutting [still managed 41st overall out of 120 cars on rally]. weve been told its probaly reached its ecu boost limit but im not so sure ,because b4 this problem we would often get 1.8-2.0 bar on gauge and never got any type of cut ?
