RS2 ECU in S2 ABY
  • Bram
    • Aug 2006
    • 2582
    Originally posted by S2central.net
    I can't remember 100% for sure but I think there is enough adaptation in the RS2 ECU to run with 4bar FPR from the ABY. It would be a little rich at WOT. Maybe some of the other chaps have some BTDT info on this.
    I had never noticed the different cam pulley on the RS2 before - is that the reason for its oddball timing setup at one tooth off the mark ?
    The cam pulley of the ADU has a different part number Paul. If I remeber correctly it has the letter "B" added to it. Also the timing is differernt regarding the Hall window angle and opening time.
    • s2avant
      • 2426
      Originally posted by bram
      I hope you are planning a custom remap as the ABY has a FPR of 4.0 bar, while the RS2 ECU software is expecting a 3.8 bar FPR (as standard on RS2). This could result in wrong A/F mixtures.
      I already use the 3.8 FPR The 4bar did indeed wreck the A/F mixtures so was swapped out. A new one will go back in when the remap is done.
      As for the timing differences I'm sure it makes a difference but the car managed 360bhp-371lb/ft on the rollers with stock RS2 software which I was fairly happy with (for now).
      Ben
      • Bram
        • Aug 2006
        • 2582
        Ben
        OK, that sounds interesting. Maybe the cam pulley timing is only needed for firering up the engine and at low RPM to keep a good idle. I can imagine that the Hall sensor is not used anymore at higher RPM's.
        Is that a correct conclusion?
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Are you sure the hall sender window is different on the ADU cam pulley? I know the cam position is different. Where is the window in relation to the TDC mark?
          SS
          • saltinot
            • May 2004
            • 1946
            #20
            I have compared both ADU and ABY spockets. The "window" is in a slightly different location between them.
            I'll post pictures later comparing them.......if someone doesn't beat me to it first.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #21
              That is weird. There's me worrying about putting the hall sender in the right place relative to the window, and the window position varies anyway.
              A picture would be useful.
              SS
              • MarT2
                • 175
                • Country: Spain
                #22
                And if I mount the RS2 camshaft pulley and hall? Is a good way for mount a RS2 ECU and have not timing problems?
