S2 and RS2 MAF differences/benefits?
  • dest
    • 4287
    I need a new MAF for my S2, is it possible to use an RS2 one?
    Would it be ok with the standard ECU?
    Would it be a straight replacement?
    Im thinking about when/if its upgraded to RS2 style spec or above in the future to save buying another...
    Otherwise Ill just stick with an S2 one
  • Animal Mother
    • Jul 2007
    • 1135
    Search button is your friend!
    Both the same except for the gauze/mesh size.
    Ican get cheap units (S2) if interested.
    UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
    Triumph Daytona 955i - mmmmmm :fire:
    80 dag dag :driving:
    • Acidburn
      • 13459
      IIRC the rs2 one is cheaper than the s2 one retailling for iirc £128 and because of the design inside does flow slightly better. Plus if you go for an rs2 airbox later I think you need one tho not sure if its a direct fit on a standard aby airbox.
      Tbh i'd speak to martyn at vagparts and check out with him.
      • rj scotty
        • May 2006
        • 2195
        Rs2 maf fits straight on aby air box
        cheers
        rich
        BUT I DON'T WANT A NEW CAR!
        1995 S2 Avant, Volcano Black
        • Acidburn
          • 13459
          Thats a bonus for dest then
          • Cullam3n
            • Aug 2007
            • 993
            yup I think simon (hpmuirt) has an rs2 MAF on his aby
            • Acidburn
              • 13459
              He switches between both an aby box/maf and rs2 box/maf depending what mood he's in.
              • dest
                • 4287
                So it seems the RS2 maf will fit on the ABY box, but will it work ok with the ABY ecu?
                  This has been well covered on the forum and there are a multitude of threads with this information.
                  The answer is yes on all counts.
                  • dest
                    • 4287
                    I was just looking on Vagparts at some bits, and noticed this on the RS2 MAF description:
                    RS2 MAF
                    MAF for engine code ADU, larger diameter compared to normal S2, this is not a direct swap for the S2 as you will need to change the air box due to the size increase
                    • HPmuirt
                      S2Forum April Fool
                      • Apr 2005
                      • 3014
                      No offense to VAGparts but that is ****** I am afraid. I can only assume that there webmaster is confused.
                      As stated above, many of us including myself have run all combinations. The S2 and RS2 MAF and airbox are identical on the outside. All differences are purely on the inside.
                      Cheers n
                      Si
                      Subtle mods here and there
                      2011 A5 3.0 TDi - Lava Grey
                      • dest
                        • 4287
                        I had already made up my mind I was going to get the RS2 one after reading this thread and chatting to Jamo on MSN, I just thought Id mention it when I noticed their description on Vagparts!
                        Maybe its to get the uneducated to buy the more expensive S2 one lol
                        • Matt_D
                          • Dec 2004
                          • 515
                          I need a RS2 maf, ask vagparts if they give any discount on buying two
                          '95 ABY Avant - Sold
                          '98 B5 S4 -MRC400+ = 464ps 741nm
