Finnaly installed my new engine (that have spent over 2 years sitting in the garage).
Now after starting I'm getting a LOT of oil in the exhaust pipe.... The car stal at ideling and only work at high revs. Software isn't reprogramed (from 220HP to around 500)
Engine is PK motorsport build. Turbo is GT30R. Catch Tank fitted but doesn't get any oil in it
Turbo checked and doesn't leak.
I'm loosing about 1L of oil in few mins.
Compressions is :
5 , 10.5 , 10.5 , 11 , 9.5
I'm guessing it could be oil rings that doesn't sit where they should be becouse of sintetic oil being used previously (previous owner of the engine , engine is 2000km old) and engine didn't work for few years. But I still can't get the idea why i'm loosing so much oil.
Any guess ?
P.S. head is mechanical. 10.8 camshafts.
Maybe any oil sensor , plug or whatever I should look into ? I'm thinking about dismanting the engine too look , but still want o know if there is anything particular too look excep oil rings.
.Turbo checked and doesn't leak.
Compressions is :
Any guess ?
. Don't know if the english translation is OK, but I'm sure you will get that it is. I suspect that the most important part is kerosine. Whole procedure is following:
