Just started to check a few of the small bore hoses over with the Mityvac.
The back two hoses hold vacuum no problem, but the front one will not hold any sort of vacuum. Is this normal?
Pauls diagram states that this hose goes to the Throttle Bypass Valve - Is this another name for the diverter valve?
Going back out in a min to check the WG diaphragm.
