Car looks good, I've seen it parked outside work a few times at lunch. Al's car was a beaut, I was jealous of how original it all was, shame it met a bitter end at the hand of an out-of-control woman...
There are many changes that were made to the S2 over the CQ, most are detailed on here but I suppose it's down to how much work you want to take on
Azman has done this conversion with a 3B so would be a good man to speak to, as would Alex at All Audi as he knows an awful lot about these cars, has concerted a B3 90q and is local too (Bristol).
I would suggest that you go for a 3B flywheel as the ABY item is a bit heavy (!) and defo go down the 996 monoblock route for brakes as the G60s really aren't up to stopping in a hurry! 6 speed box, 5 stud hubs and larger S2 front struts are a good plan too IMHO.
If you need some spannering help then give me a shout, always happy to have a play
Oh, and get that ECU off to Paul for some home fried action ASAP.
Azman has done this conversion with a 3B so would be a good man to speak to, as would Alex at All Audi as he knows an awful lot about these cars, has concerted a B3 90q and is local too (Bristol).I would suggest that you go for a 3B flywheel as the ABY item is a bit heavy (!) and defo go down the 996 monoblock route for brakes as the G60s really aren't up to stopping in a hurry! 6 speed box, 5 stud hubs and larger S2 front struts are a good plan too IMHO.
so thats abit of a ******
great job mate!
