Hi all - nope, I've not fallen off the end of the world, just been busy with real life. Thanks to all you guys for help and encouragement with all the bother I've had with my car.
Took the front end off today. The Cam wheel is knackered. The timing on that was out, and the 'woodruff key' (got a friend who knows more about these things than I. I'd have called it 'the bit that sticks out') totally sheared off. Exhaust and Inlet cams both out by a couple of teeth, but I think I've been lucky (famous last words) and the valves are still ok. The inner shiny wheel was bent as if by a screwdriver, and worn on the inside.
Tensioner was hand tight (I could just about pull the timing belt off) so here's my question:
What should the torque settings be for everything around the camshaft area?
Camshaft bearing studs? Tom (Audiman) in his (helpful, by the way) guide says 15nm, but two studs sheared off at that.
Cam pulley?
The stuff at the front - pas belt, timing belt tensioner etc.
I did try and get a haynes manual on the Audi 80, but I believe they've helpfully missed out the years 89-95, unless anyone knows different.
Anyway, bits on order from the local stealers (with an extra £7.50 to pay to have em by tommorrow cause I was half an hour past their cut off at 2.30pm to order. Cheers guys
) and hopefully, maybe, by some miracle, the car will be running again tommorrow. I hope. Maybe.
By some miracle. Etc.
By the way guys, if all the bits on the front are as loose as mine were, it'll take you about half an hour to do a timing belt change
Cheers for any and all help
Paul
Cam pulley?
) and hopefully, maybe, by some miracle, the car will be running again tommorrow. I hope. Maybe.By some miracle. Etc.
Paul
)7a cam now. Will post a picture of the damage.
