My somewhat damaged cylinder head
  • pastures16
    • 2058
    i thought you should never retighten plugs
    94 s2 avant
    aoc member 1116
      Never back off and then retighten. Just tighten. Clockwise (duh).
      30 Nm (22 lb ft).
      Better check your plugs.
      Now.
      • pastures16
        • 2058
        what i was trying to say was that you should never retighten plugs you should use new ones
        94 s2 avant
        aoc member 1116
        • GT500
          • Jun 2006
          • 2181
          I agree with the yank,
          Torque plugs!
          I often find loose plugs or cars I haven't had in before, every time the crush washer has not been crushed!
          Never had a plug come loose.
          I can just see it now,, sat at Spa " sorry sir, you didn't finish the race because I torqued your plugs in and they fell out!"
          Just look at how much thread actually threads into the head, loads, you would have to be ham fisted tossa strip the thread.
          If you haven't been trained how to do it, don't bother.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
            Worth replacing the one way valve in the PCV system, maybe the crankcase has been getting boost pressure. Chances are though that the gaskets have gone hard and just started leaking.
            • HenryG40
              • Jul 2007
              • 115
              Here are the bad pictures:
                I had the same problem last year and had to have the thread repaired in the head, replace coil pack and lead. Just double check the plugs are tight a week or two after fitting
