I have to ask these questions for an UrS6:
1. What is the standard wastegate spring pressure and does this take into consideration the factory setup? (i.e. 1.1, 1.3, 1.5, etc)
2. If you went and bought a “1.9 bar” spring and fitted it into a factory set wastegate top cover, would actually have a higher spring pressure than the ‘1.9 bar’? (i.e. is the factory setting in the wastegate top cover worth say ‘0.2 bar’ so you would actually have ‘2.1 bar’ effective?)
I cannot find any reference to the factory spring pressure anywhere and it will help me understand the full picture for comparative testing I might do. ((i.e. taking out a ‘1.5 bar’ spring and fitting a ‘1.9bar’ spring, etc.) Before and after, etc)
Regards,
Andy H.
Regards,
Andy H.
