what to do while engine is out?
  • MGaz
    • Feb 2008
    • 698
    my engine is coming out soooon!!!!!! so.... while its out is there anything worth doing while the engine bay is vacant. ?
    Or maybe anything i should replace seeing as i have the chance?
    Any recommendations?
    cheers.
    C4 A6 AEL avant quattro: daily
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    check steering rack for leaks or service!!
    • Acidburn
      • 13459
      Yeah definately the above.
      depending which engine it is, if its a 3b check the dizzy/gear and the oil pipes/breathers down underneath that.
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Where do I start?
        SS
        • s2_bo
          • Oct 2005
          • 6067
          Dont ask Stu, he'll just make you cry.
          91 S2 coupé - RIP
          98 S8 - Luxury barge
          • Acidburn
            • 13459
            have a look at his thread or terrybullwon's or s2driveruk's one as they've all had there engines out so should be a good start.
            • terrybullwon
              • Mar 2006
              • 8782
              Originally posted by 4WheelDrifter
              Where do I start?
              Tell me about it
              Depends how big your wallet is...
              Chef
              • Acidburn
                • 13459
                and how much time/space you have.
                First off what engine is it your taking out and whats it in? an s2, type 85? etc.
                • Acidburn
                  • 13459
                  Originally posted by terrybullwon
                  Tell me about it
                  You could become a chef, as a mod on here said before, they're minted
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    they're minted
                    Prefer mine covered in honey and slow roasted...
                    Carlos.
                    • Puglife
                      • Jun 2006
                      • 731
                      lol well they clearly don't do much work as they're often seen drinking
                      I'm sure i remember Mgaz asking about 20v conversion into a T85 CQ....
                      If so whilst engines out replace what you can, clutch slave cylinder will be easy to do now, check steering rack tie rods, ARB bushes, any rust you can sand back primer and spray over.
                      Jay - pug_life85@hotmail.com
                      1986 Audi UR quattro - WORK IN PROGRESS
                      1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                      • Graham
                        • 1622
                        Clutch and slave cylinder, a full engine bay detail, wax and polish. Maybe a new down pipe (3"), new fuel lines from front to back. I am planning on doing mine in stainless steel. Got my tube benders, and flaring kits. Brake lines from ABS......................Where do you want to stop.
                        Graham
                        • kwlw
                          • Sep 2004
                          • 1025
                          • Country: Lithuania
                          On typ85 you need to install firewall fix bracket. Not actually need, you just MUST .
                          Sau
                          • Acidburn
                            • 13459
                            Have you got anymore info on this firewall fix?
                            never heard of it commented before
                            • MGaz
                              • Feb 2008
                              • 698
                              I did ask,.. unfortunately for reasons of insurance costs i've had to put that on the back burner for now .
                              instead im fitting a 2.5L KV Gti engineering lump in to the typ-85 CQ instead.
                              Do you think i should get new rubber engine mounts? or just leave them if they look ok condition. infact, are there polly versions available? any good?
                              how about gear box mounts? are they easier to replace with engine out? (they prob don't need doing tho)
                              Schrick 272 cam
                              ITG filter
