I've been having problems getting my aan coupe running right...
it hits a wall under boost.....
does anyone here know what numbers I should get for voltage from my coils?
I used a Thexton No.404 adjustable ignition spark tester
30kv coil 1,
25kv coil 2,
27kv coil 3,
30kv coil 4,
30kv coil 5,
I tried on each to go one turn further and such, so they pretty much maxed out at those numbers..
on the card it has requirements for some domestics, but I have no idea what I should get out of my aan coils...
are they all low? (gm distributorless ignition should get good spark intensity @ 36kv)
I figure that if they aren't sparking under simple cranking to the required point, then there is no way they could be sparking under the higher output conditions where my problems lie.....
oh yea, big p.s. even though the body of the gapper is enclosed in plastic, don't hold it......
you will get shocked
thanks
30kv coil 1,
25kv coil 2,
27kv coil 3,
30kv coil 4,
30kv coil 5,
thanks
