I was just about to post 'oil leak' when I saw Ben's post hence the 'another one' bit. I've only got one, but it's annoying.
Front driver side corner, I'm betting the oil pipes round the turbo area - one of those.
I don't think a spacer was used on the turbo oil feed pipe, so odds are it's that one.
What are you bigger turbo guys using for oil pipes? The braided ones Audi use seem a bit crap and leaky to me, and they prices they charge for em... well, It might cost the same to get something stronger (ok, albeit it'll be in blue, or red, or some other bling colour) but what, and where from?
Gonna have to take the front end off anyway to properly sort the rubber hoses from turbo out (the turbo to intercooler one gets sprayed in hot oil at the moment.)
Time to get my hands mucky again. For years I worked on friends 'simple' cars - vauxhalls, fords, toyotas - whatever bangers they bought, they came to me for fixing. Now this thing comes along with pipes all over the shop and I'm having to relearn where things go, how things work again. Expensive learning curve so far
PJ
I think it's part 034 145 745 D that's 'popped'. At first I thought it was a lower pipe that was spraying up. but more likely a higher pipe that's dripping down
PJ
