I'm in the process of trying to get myself a nice set of JE pistons. First, I was thinking of ordering "the usual stuff", but after reading a couple of threads here my head started spinning.
I know (since I read them...) there are several threads regarding JE pistons, but hey, stuff could have happened since then.
So I got a couple of questions...
- Where to order?
- Options? I guess the first orders were pretty "stock", but that some people later on ordered with gas ports, total seal rings, grooves, and so on. If You have JE pistons - what did you get and what are your experiences?
- Lowering the valve pockets - I've seen booth .5mm and 1.5mm, what's really necessary? pros/cons?
- Does the dealer have blueprints of the stock piston, or do I need to send one in, or perhaps get a ref #?
- Estimated price tag?
Thanks in advance!
Floddy
- Where to order?
Thanks in advance!
Floddy
, also speak to Aelred.
I'll weigh my pistons for you and see what the difference is, its not much but you can tell by holding them in your hand the JE's are lighter.
