Boost gauge and fault code
  • Dr H
    • 1175
    I fitted a boost guage today to check if I'd plumbed eveything back together OK when putting the turbo back on. Easy or what don't know why I didn't do it before. Took ten mins to plumb it in. I haven't mounted it anywhere yet though.
    Anyway readings are about 0.8 bar and 1.2-1.3 bar o/boost. I get these levels at about 4-5k rpm. This is OK yeah
    Also my car was showing fault code 2132 (coolant temp sensor related) but it feels fine and doesn't show any of the suggested symptoms (from table on S2 Central) could it just be that the coolant level warning light came on after fitting the turbo (needed topping up due to losses)? Would this record this fault code?
    Leigh
    Ex 1994 Avant - now driving a Lotus 340r
  • APNess
    • 479
    Boost level should be 1.05 to 1.1 bar I think for a stock S2 on overboost. 0.8 bar for normal (foot depressed slowly to floor) sounds about right I think. You sure the car hasn't been chipped before?
    'The Bacofoil Express'...
    No more.
    Leon TDI 150 run in now.
    Very slow.
    Needs a chip.
    • Dr H
      • 1175
      The car was once 'superchipped' for three weeks. Sounds weird but that's what Quattro Sports tell me. They then put it back to standard. I though it was 1.25 on overboost.
      I guess there are no leaks so I'm happy
      • audiman
        • 4827
        1.2 is ok.
        Does that Fault code come back after clearing it? If not then don't worry about it. The low coolant wont have made it come on. It may be an old code??
        Burning question, does it still smoke??
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • Dr H
          • 1175
          Like the pun - 'burning' question does it smoke!
          Answer is no, not at all. So that's good news. I'm going to put the catalytic converters back on in a couple of weeks and see if the weird grey smoke comes back. If it does then it has to be the CATs.
          I cleared the code, drove the car and checked again today and I get the good old 4444 so who knows. I guess the car is fine so I'll forget about it
          Leigh
          • audiman
            • 4827
            Leave the cats off. QST claim a whopping 10 bhp increase from chucking them! Just keep them to one side for MOT tests
            Audi UR Quattro
            • Mark Halligan
              • 2001
              Tom,
              I thought that we did'nt need to have cats fitted to pass the Mot test
              Mark.
              Mark - Modded
              • APNess
                • 479
                My car doesn't smoke at all on startup now that the cats have holes where the honeycomb used to be, and lag is just about gone - dunno about the hp increase yet though, and I'll have to get the emissions sorted out at *some* point I know.
                No more.
                Very slow.
                Needs a chip.
                • audiman
                  • 4827
                  They will, in actual fact the 3b S2 is not listed correctly in the Ninth edition emissions guide, supplied to all MOT stations. It is listed as a 2.3, could get away with that one. ABY is listed correctly, and it has a set value for cruise speed (2500-2800rpm). dont have the figures here at home can post them tomorrow m8.
                  But yes cat are NOT needed. Just has to pass the test!!
                  Audi UR Quattro
                  • Mark Halligan
                    • 2001
                    Thats a relief, as mine are at the bottom of the garden now rotting next to the compost heap
                    Mark.
                    Mark - Modded
                    • APNess
                      • 479
                      "mine are at the bottom of the garden now rotting next to the compost heap "
                      Ahhhh so THAT's where egg plants come from. I'll have to try planting mine as well.
                      No more.
                      Very slow.
                      Needs a chip.
