8mm ht leeds for a 3b
  • denniselbows
    • 740
    just need your thoughts please i'm looking to replace my ht leeds on my 3b with some 8mm ones. i have been trying to look through some threads but with no luck to what you all have used. all i have found on the net so far is the Magnecor stuff but they has a note about not using oe suppressed spark plug boot. now not knowing if this maters or not i am unsure if they are ok or not.
    cheers
    dennis
    never set your expectations to high that way you are never disapointed
  • terrybullwon
    • Mar 2006
    • 8782
    Is there not a kit you can buy and do it DIY?
    Chef
    • denniselbows
      • 740
      that could be a option. i shall keep hunting may end up getting some from 034 but wanted to try and get some from over here.
      • LHD_Kid
        • May 2006
        • 3695
        I use 8.5mm red KV85 Magnecor leads with no problems at all... due to their design they don't need supressed boots... to quote Magnecor... Metallic
        Inductance Suppressed Conductor will suppress EMI indefinitely...
        nothing bad to say about them....
        Chris
        • denniselbows
          • 740
          what about the m4/pin fitting is that the correct type for the dizzy pins/terminals
          • LHD_Kid
            • May 2006
            • 3695
            Hmm, to be honest, I am not sure whether the correct fitting type is M4 or DIN...
            I suspect this is not difficult to find out though....!
            Sorry I cant tell you that one......!
            Chris
            although, if you look HERE you can see pictures, I think it looks like DIN type, but you will be able to see from what the dizzy looks like and the description here
            • denniselbows
              • 740
              thanks spot on info i'll have a look on the car to find out which type it is.
              thanks chris
              • amanda
                Account Disabled
                • Nov 2006
                • 524
                Hmmmmm I had magnicor's on my red urq and they caused nothing but probs with her, a swop back to oem ones and she is now fine.
                • Markarina
                  • Mar 2006
                  • 511
                  • Home: United Kingdom Current: Switzerland
                  I've go the 8mm magnecor on mine and had no problems with them at all
                  • PeteRR
                    • 1326
                    I had 7mm Magnecor's on my old quattro, as well as 8mm one's on three other cars in the family. No probs with any of them, quality leads as far as I'm concerned.
                    In fact, I've just ordered some KV85's for my current quattro.
                    • denniselbows
                      • 740
                      i looked at the kv85 and thought they would be the ones for me but how have you got round the m4/pin fittings as the dizzy is din fittings on my car.is there a different dizzy cap or am i not looking at the right ones (but are listed as for s2 3b engine)
                      • s2_bo
                        • Oct 2005
                        • 6067
                        What did a set of KV85's cost a where did you order them from?
                        91 S2 coupé - RIP
                        98 S8 - Luxury barge
                        • PeteRR
                          • 1326
                          I got mine from www.spark-plugs.co.uk. I got my last set from them and was pleased with the service and reasonable prices.
                          They are however seemingly made to order, so I'll have to wait a week or so to get them.
                          They cost £118.57 all-in for the RR, but should hopefully be fit-and-forget for a good long while and handle the heat a bit better (my o.e. set's insulation has gone fairly hard).
                          The set I fitted to my old car also stated that they were m4/pin fittings, but they plugged straight in. So I'm not sure if there will be an issue there or not. I'll let you know.
                          • PeteRR
                            • 1326
                            Well, I fitted my KV85's today and they went on a treat.
                            The fittings at the dizzy and coil are exactly the same as the o.e. leads, and so of course plugged straight in. As did the connectors at the spark plugs too (the top end is a slightly different design, but arguably better as they help prevent any cr@p from entering the plug holes).
                            And despite their slightly larger diameter, the KV85's do indeed fit very nicely under that black plastic cover over the leads too.
                              Had probs with Magnecors on a few old Golfs, get a set of OEM Bosch ones instead, much better quality IMO.
