right.. i've got the GTi engineering RE2500 engine in now.
had a problem with the baffled sump as the baffles had cracks in them, so had to weld them up.
and a few problems getting the oil pick up fitted. But at least now it in anyway.
A question i have is, because of the new piston rings, what would you say is best advice for running them in?
i've got mineral oil in the engine at the moment, and so far i've done about 200 miles and have not revved past 3,000 rpm.
A friend of mine recommended a 500 mile run-in period, but another friend said 1000!
Just after your advice on this guys... cheers.
Gaz.
Gaz.
:mischeif:
