92.8mm stroke crank...
  • Flat on my back
    • Jan 2007
    • 2449
    Sorry to drag this old one up again...but do we have a definite answer as to where the 92.8 came from?
    Is this true...
    The 92.8 mm crank was used in the type 2 T4 models from 1991, the engines being the 2.4 litre diesel and the 2.5 litre petrol. The engine codes are AAF, ACU & AEN (petrol) and AAB (diesel). The VW part number is 074 105 019 E. To use this crank in a 2.2 KV/KU or 2.3 NG block (or even the JS or PS 2 litre), all you need to do is a little clearancing work around the middle dead centre point for number one con rod where it gets very close to the sump gasket area. You use the original 144-mm rods but you need 3A Audi pistons (82.5-mm or 83-mm if you need to re-bore an NG 2.3 due to bore wear). The crank can also be used in the 7A 20v (I am just about to build one) but you need 6A Audi/9A Corrado/Passat pistons and you need to modify the pistons for the oil jet.
    Any T4 'junkies' know...
    Carlos.
  • anton
    • Jan 2005
    • 802
    If this is the same 92.8 crank that 034 sell i read on motorgeek that it was never fitted to a production car, they came on vag engines used for genorator purposes. at least i think it was a genorator, someone correct me if i'm wrong.
    Ant
    91' Coupe quattro 20v - project
    KW V2s and other goodies
    now gone
    03' BMW 330CI - Sold
    08' A5 Coupe 3.0l tdi quattro - Sold
    57' BMW 525d M Sport Touring
    • AndyP
      • 6049
      I've got an AAB engine from a T4 and it's got a 95.5mm crank. I've heard the 92.8mm came from a South African spec T4 but never been able to confirm this.
      • 20Vcqdriver
        • 829
        92.8mm
        Your right the 92.8mm came from a South African 5 cyl petrol engine. Had a long chat with Steve Cresswell of C&R about this last year when I was looking at taking my 7A to 2510cc. 034 ones are made specially hence price. Have been told that these are getting as hard to obtain as rocking horse ****!
        1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
        • Flat on my back
          • Jan 2007
          • 2449
          b
          ugger...anyone know a breakers in SA?
          Or any SA members confirm this?
          Carlos.
          • Blauer Donner
            • Jul 2007
            • 44
            Thats our 2.5l Chrome Moly light race crank
            kind regards
