Bigger Turbo......
  • jubjub
    • Nov 2003
    • 1239
    Bigger Turbo......
    I think i am in need of more power So how easy is it to upgrade the turbo? If i go for a KKK26/27/29 is it a straight forward fit? What other bits are needed,pipes/hoses/injectors etc? Dare anyone answer, what sort of cost would i be looking at?
  • Doug_RS2
    • 3847
    It is not a straight fit.
    You need a 10mm spacer for the oil feed line - Tom is getting one made for Paul just now.
    I think the standard water feed can be slighlty bent to fit.
    You need an adapter to get the hose to the inlet of the turbo to fit - or go custom inlet hoses route with cone. Mihnea can get a metal adapter - I'm not sure if that can be used with the standard hose (just chopped up a bit).
    RS2 injectors should be ok.
    Good for 420bhp (maybe a bit more) - not that hard an upgrade - the cost will be the turbo, maybe the metal inlet pipe and maybe a couple of silicon hoses - around £1300 + remapping.
    Nick has just done this on his RS2, apart from he is going with the MTM inlet as well.
    Other options would be the Garret style turbos - I don't know anything about them.
    • APNess
      • 479
      You can use a 70-60mm reducer hose to adapt the existing inlet pipe to turbo (if it's a K26/27 it's 70mm inlet - Doug is k26/27/29 bigger ?). I nicked mine off my MarkH modded i/cooler (now replaced) and used a piece of stainless steel pipe (would you believe, a exhaust trim - I was in a hurry, dammit) to strengthen the hose so you can put a clamp on it. SFS had 4 left when I ordered my last one. About £28 incl postage and circlips.
      The 10mm spacer thing is a must though, unless you wanna twiddle your thumbs after finding out the leaky way that you can't do without it (Like I'm doing )
      PJ
      'The Bacofoil Express'...
      No more.
      Leon TDI 150 run in now.
      Very slow.
      Needs a chip.
      • Doug_RS2
        • 3847
        Turbo inlet is 70mm on my k26/27/29
        • jubjub
          • Nov 2003
          • 1239
          Whats the benefit of the MTM inlet? Do you need an exhaust manifold, SportQuattro/custom ?
          • Doug_RS2
            • 3847
            How much power do you want Jubjub? Have you had your car remapped by Mihnea yet?
            • OZzzt
              • 43
              My K27/29 has a 107mm inlet. Even bigger than 4". Try finding a rubber hose for that!
              OZzzt
              • 91_S2
                • 612
                Doug,
                Could you - or anyone - explain the 3 designations 26/27/29? Two I can see - but have been wondering about the third.
                • Doug_RS2
                  • 3847
                  K26 hotside, K27 coldside compressor housing that is modified to take a k29 compressor inside it. I think!
                  • 91_S2
                    • 612
                    Cheers Doug,
                    Sounds logical. When in doubt one would have to look at the spec plate to see which housing carried the larger wheel.
                    • timucin
                      • Nov 2003
                      • 869
                      • Country: Turkey
                      why dont you use american turbos?
                      much cheaper ,almost half price..?!?
                      turbonetics?turbo city?etc..
                      Quattro
