question about the wastegate
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    is it supposed to let exhaust out on idle??
    mine is letting out. I think its a bit much, but not shure.
    appriciate answers:thumb:
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • s2_southwest
    • Oct 2004
    • 823
    i didnt think they were meant to, as i remember when i removed mine the valve was shut hard (against spring pressure) and until the exhaust pressure over comes the tension in the spring then it will open. could be wrong, just my thoughts
    Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
    • gedu
      • Feb 2007
      • 295
      exhaust or boost pressure, mainly boost in stock configuration.
      All quattro products have been dermatologically tested, and are safe for daily use.
        The valve should be shut at idle.
        • urquattro-island
          • Mar 2006
          • 1915
          ok
          thats my thoughts also, but the exhaust is going through, but it shuts, and the ceramic ring is in place??? weird??? Have to take it off again..
