Flat spots over 5,000rpm since RS2 turbo fitted?!
  • Rusty
    • 18953
    Hard wire the FP to the battery using a relay, that should get you a little bit more.
    • Rusty
      • 18953
      This seems more and more like fuel to me. My car was really low today and I eas doing a couple of WOT runs and there were a couple of hiccups that I can only assume are from the fuel being thrown around in the tank and the pump not getting a 100% supply Reminded me of your predicament.
      Things to check are fuel pressure at WOT (get a gauge fitted), fuel filter (has this ever been changed?) and the voltage drop at the fuel pump.
      HTH
      • DarrenM
        • Aug 2007
        • 1227
        Cheers for the input Andy, I've got a meeting up near Banbury way tommorrow so popping in to see the boys in blue..
        • Rusty
          • 18953
          Get a fuel pressure gauge in there and do a few runs
          • CliveH
            • Jun 2005
            • 1319
            #35
            They'll sort you out!
            Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
            Present: S4 B8 avant, MRC Stage 2
