Flat spots over 5,000rpm since RS2 turbo fitted?!
  • DarrenM
    • Aug 2007
    • 1227
    Since having the RS2 turbo fitted im getting a few flat spots over 5,000rpm. She spools up and revs fine up until then,boosting to about 1.5bar etc but then between say 5 & 7,000rpm im getting about 3 flat-spots.
    When hits flat spot over 5k, boost drops right off, then back in again, then off,then in again...its so annoying. Its had a new Homefry to suit RS2 turbo on current set up (in fact, when i mentioned problem to Paul he kindly sent me another set of chips to try but still getting it).
    Have been advised to get injectors pressure checked & cleaned & change Boost solanoid valve, havent done either as yet but wondered on any other possibilities?
    cheers
  • Rusty
    • 18953
    Bit of a strange one there... not got any pearls of wisdom I'm afraid other than the usual, check everything, check it's holdng pressure, clean everything...
    I thought my car had broken the other day, turned out I'd forgotten to reattach the TPS plug
    • ericd
      • Nov 2003
      • 1240
      cheers
      you got green injectors ?
        Sounds a bit like Sammo's car, boost... low boost... boost... low boost.. someone said possibly wastegate sticking.
          Got good fuel in there?
          • DarrenM
            • Aug 2007
            • 1227
            Standard ABY S2's at the mo. i know RS2 manifold,injectors,IC etc would get optimum from it but thats all to be collected and go on later in year. Why, do you think symtoms are current injectors maxing out??
            • DarrenM
              • Aug 2007
              • 1227
              Yep, only ever run Tesco 99 or V-Power. Was running fine before new turbo went on with the standard turbo and usual 280 homefry.
              • Rusty
                • 18953
                Is the map designed for S2 or RS2 injectors? You could fit a higher fuel pressure regulator to overwork the injectors a bit but that really is a short term fix
                • DarrenM
                  • Aug 2007
                  • 1227
                  Map is designed for RS2 turbo running S2 injectors, have tried several chip combo's from Paul but still get same probs. dont know whether to get current injectors cleaned or get some RS2 injectors instead. Either way, could do without spending more £££ at the mo, especially if that doesnt cure it..
                  • Rusty
                    • 18953
                    Get the fault codes read or do a few VAG com runs. All Audi in Bristol will be able to help if you're stuck.
                      As stated on PMs - this setup is critical on fuel... Needs to be 98RON or better and the fuel pump, filter, FPR and injectors must be in tip-top shape. As stated by Andy, you could run a variable FPR to give you some more headroom.
                      I would also renew the WGFV if its old and try a different MAF just in case. I know the chips are good on that setup.
                      If you are thinking of going for RS2 injectors then its different chips and a 3bar MAP setup to get the most from the RS2 turbo when its properly fuelled.
                      Paul
                      • Rusty
                        • 18953
                        There's also the option of hardwiring the fuel pump to the battery to negate the voltage drop over the standard wiring loom.
                        • EspenW
                          • Apr 2007
                          • 1534
                          • Country: Norway
                          cheers
                          I had a similar problem recently, turned out that one of the spark plug connectors (sits between the plugs and coils) were hosed. Check condition of plugs and the resistance of the plug connectors (should be approx 5K ohms)
                          1994 80E Avant
                          1986 2L Golf 2 on Alcohol
                          • Rusty
                            • 18953
                            Check your plugs are tight too.
                            • quattronutter
                              • Jan 2005
                              • 690
                              may have a weak fuel pump,check codes first and pressure test
