over boost problems sometimes
  • keithsw0
    • May 2005
    • 571
    engine cuts out for a few seconds if you boot it at about 3000 rpm i have changed the over boost switch already that seemed to sort it for a while now it plays up sometimes and not others
    due to go to south of france in it soon so want it sorted for the nice twisty roads
    if any body has any ideas that will be great some body has put a nut on the waste gate so not sure if this is any thing to do with it
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    no the nut in the wastegate is only to stiffen the spring manually and achieve more boost thorughout the rev range(but if there is not mapping for it will go lean).Possibly a MAF failure if there are cuts like that and a bunch of other things.Lots of similar threads about this problem,have a look in search
      Boost leak or MAF. I would clean the MAF connector and see what happens, its usually this when mine does it. If not look for a boost leak.
      • keithsw0
        • May 2005
        • 571
        boost leak
        thanks john will give that a try it is only sometimes
        cheers keith
