Homefry+forge DV what spring?
  • andyg plym
    • Nov 2006
    • 4646
    Been reading some old posts and was wondering what spring to use in my forge recirc DV?
    Green is in there at the moment, but i see you can have different colours relating to spring pressures.
    Yellow springs are rated for 1.5 Bar, as the homefry is set to 1.4 shouldn't i be investing in the yellow one?
    Or is that 1.5 at the red-line?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    try with the blue spring and if you dont like it,try with the yellow with
    1 or 2 washers....
    • jameswkr
      • 538
      FWIW - I run Forge with yellow spring (no shims) in reverse orientation (Jamo initiated the last thread I recall on this topic). Mine is still on standard ECU. Definitely worth experimenting to see if you/your car like it.
      • Rusty
        • 18953
        Lellow, no shims
