3B wot problem
  • lynx
    • Jan 2005
    • 125
    3B wot problem
    Hi,
    Actually it' s my friends audi 200, but still 3b engine, so maybe someone could help.
    He bought car without engine 2 years ago and now tried to start the car with "new" engine.
    Main problem is WOT. When I press WOT, engine going to "choke", in any rpms and going to lose rpms. Looks like ingnition is retarded, because in this time turbo starts to spool, even rpms goint to drop.
    When I trie to play with throttle, all seems to ok, no matter what rpms but as soon as I make pedal to medal, problem there (no matter, if car idles or running).
    So far tested:
    Another ECU/TPS/MAF,nothing.
    what may cause this thing?
    thanks,
    marek
  • Rusty
    • 18953
    Check the ECU grounding is correct on the engine, same for the coil packs. BTDT.
    • Knight Rider S4
      • 3541
      Hot or cold ...does the fault happen?
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
      • lynx
        • Jan 2005
        • 125
        Ground OK, 3b have only one coil
        No matter
        thanks,
        marek
        • 20Vcqdriver
          • 829
          Maf
          Sounds exactly like the issue I had a few weeks back, turned out to be the MAF faulty.
          1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
          2004 A4 2.5TDi convertible, re-mapped to 180bhp
          2011 A5 sportback 3TDi-Backbox delete, remap
            Yes, MAF or a boost leak.
            • lynx
              • Jan 2005
              • 125
              as I said before, we have tested another MAF (with is working perfectly other car), and tested boost leaks, nothing.
              what else could I check?
              thanks,
              marek
              • 20Vcqdriver
                • 829
                Can you hear the throttle switch working? If its still in idle mode it will cause same issue.
                Best to get VAG-COM attached and see what codes come up.
                • s2driveruk
                  • 12696
                  boost leak if it feels like its 'bubbly' at wide open throttle IMO
                  1992 3b S2 Coupe
                  • lynx
                    • Jan 2005
                    • 125
                    I have changed TPS, witch also working just fine with other car
                    Vag - com doesn' t see any problem with the engine - no any fault code.
                    We tested yesterday intake and with 1,5bar and there was zero leak.
                    thanks,
                    marek
                    • tgriff
                      • May 2007
                      • 41
                      check what plugs you have my 3b did similar at wot ,turned out to be crap champion plugs fitted by previous owner
                      • anton
                        • Jan 2005
                        • 802
                        i thought at wot these cars went to set map, as in only maf and hall sender have input? have you checked hall sender? also could be anything ignition related, i had a faulty hT lead but only ever misfired on full throttle. lack of a good spark can feel like 'choking'
                        Ant
                        91' Coupe quattro 20v - project
                        KW V2s and other goodies
                        now gone
                        03' BMW 330CI - Sold
                        08' A5 Coupe 3.0l tdi quattro - Sold
                        57' BMW 525d M Sport Touring
                        • urquattro-island
                          • Mar 2006
                          • 1915
                          • Home: Norway Current: Iceland
                          sounds
                          like the problem i had, and it turned out to be, one of the little hoses at rear of IM. check them was just a little hole.. and after it was fine
                          japanischer industriabfall nein danke!!
                          www.rackeltrim.se Icelandic Division
                          • lynx
                            • Jan 2005
                            • 125
                            thanks all who tried to help, it was broken maf wire
                            thanks,
                            marek
