wobbly bottom pully
  • andyg plym
    • Nov 2006
    • 4646
    wobbly bottom pully
    ok cards on the table time, my last 3 cars have been s2's and have all had the same problem which ive never bothered about: the bottom pulley wobbling.
    Having suspected the reason for this and having a chat at the last meet ive come to the conclusion that either the crank is feked or i need a new pulley.
    any btdt's? must be others as i have had this on 3 s2's now
  • terrybullwon
    • Mar 2006
    • 8782
    Is your timming gear cracked by chance? I have never seen this, i think its very scary!
    Chef
    • andyg plym
      • Nov 2006
      • 4646
      dont think so,car drives fine,no vibrations,idles sweet too.
        Its a vibration damper, the pulley is rubber mounted, ok to leave alone if its just wobbling a tiny bit, replace if it wobbles a lot. I actually ran a really wobbly one on the ur for years, the engine was smoother though when it was replaced.
        • andyg plym
          • Nov 2006
          • 4646
          come to mention it the rubber looks a bit perished if i remember right. if i get a new pulley hopefully that may cure it
          • terrybullwon
            • Mar 2006
            • 8782
            All ways the way.... Its going to be up setting the crank alittle if its off balance
            Chef
            • denniselbows
              • 740
              could be down to the dampening rubber being pulled out of shape by the v belts. if the rubber is getting warm from the engine heat it could get a bit soft. ok when the engine is running but when it is stopped the tention from one of the v belts may pull it to one side and when the rubber cools it may stay in that position. so when you start up again
              you have a wobbly pully once wormed up it may come tru again. just a thought
              never set your expectations to high that way you are never disapointed
              • andyg plym
                • Nov 2006
                • 4646
                thats a thought mate, my power steering belt runs inside out (it is old and need to replace),ive adjusted it and turned the right way but it always flips itself inside out again.Been like it since i bought it,and ive done silly speeds in it
                it runs sweet though!
                • volcano rs
                  • Jun 2005
                  • 2265
                  i had the same problem in the end i replaced it with an alloy one ( after i had bent 10 inlet valves ) no more wobble .
                  i also replaced the crank sprocket with a steel one .couple of pics
                  • andyg plym
                    • Nov 2006
                    • 4646
                    mmm nice,e did you get those and was it expensive?
                      Andy, I had a wobbly puilley and it was been a broken woodruff key on the sprocket, its really not with taking the chance for a £20 part IMHO.
                      worth checking.
                      • andyg plym
                        • Nov 2006
                        • 4646
                        worth checking.
                        I agree mate,il get it done along with the cambelt,il get some local s.w.i.l.l.y to do it
                        • aelred
                          • Jan 2005
                          • 761
                          I believe i have a brand new 3B pulley for sale if any good
                          Aelred
                          • Bram
                            • Aug 2006
                            • 2582
                            Is that pulley from Mapleracing in Canada?
                              S.w.i.lly
