Are there solutions to make the 034 motorsport 3B streetdensity engine mount work on the ABY? I still have a pair laying around, since the standard ABY engine mounts are too weak and I believe the 034 pro mounts are too hard.......
Could I make a ring with different holes to fit the engine mount holes and the ABY chassis holes?
The only solution is to drill new offset holes in the engine arms.
I wasn't comfortable with this in terms would it affect the strength of arm mounting hole.
I don't believe that the standard engine mounts aren't strong enough to be honest.
I think a new set with an uprated snub mount will be fine and this is the route I'm going.
what kind of money are we talking for new mounts gents? I believe i'll be needing new ones for the ABY i'm getting. Ciaran - you'll be just the chap to lend me a hand, having done your own (I know, I know i'm so good to you)
1990 CQ20v
2001 3.0 B6 A4 Avant Quattro Sport
