Is it true that AAN doesnt have owerboost option? I have instaled AAN engine to S2 and I have MTM remaped AAN motronic. IS it beter to get aby one or should this be ok? The car is not on the road so I cannot test the performance.
AAN vs. ABY motronic
AAN does have overboost! There's not much between the AAN and ABY ecus. Someone has put an ABY ecu in my S4.'93 S4 Avant now back on the road complete with new shiny go faster bits. -
I seriously doubt that MTM vould take this ceap trick. An i newer tested it due to the car is in the garage. It was basicly a metter of someone claiming that there is no owerboost feature.
Thanks allS2+AAN in progress (again), BMW 3 compactComment
Doesn't the MRC high boost chip go up to 1.5bar and isn't this above stock overboost pressure? I wouldn't know as I have a 3B. Although my point is pointless
if the claim was that AANs in general have no overboost rather than your MTM AAN doesn't have overboost.
David
'91 3B S2 CoupeComment
It depends on who has made the chips. Some people do it with overboost, some do it without (constant boost all the time). There's no strict rule.
Sau200 20vt 88' 3b, human carrier
CQ typ85 with AAN inside, see project blog at http://kwlw.blogspot.comComment
