Leaking WGFV
  • Dingo
    • Jan 2008
    • 229
    Leaking WGFV
    Got my new boost leak test kit and after fiddling around for the morning discovered that the only leak I have is coming from the wastegate freq valve, not from the pipes or the joints but the actual unit its self, is this normal ?
    It starts to leak at about 0.7 bar, but this unit isnt normally under this much poss pressure is it ? so does this matter at all or is it knackered ?
  • BRY
    • 3755
    Smash it and buy and a new one.
    Or the other way round.
    • Acidburn
      • 13459
      lol yeah i've heard of them cracking etc and people trying to glue them back together.
      • EspenW
        • Apr 2007
        • 1534
        • Country: Norway
        Mine would leak at 1.5 bar, and caused boost to skyrocket to 2bar+
        I don't trust them at boost levels over 1.7 bar (and have seen too many blown engines due to blown N75's at lower boost levels too). I'm running a Turbotech boost controller upgraded with a ceramic bearing. Simple and works well.
        1994 80E Avant
        1986 2L Golf 2 on Alcohol
