AAN Head Required
  • hoffer76
    • Mar 2008
    • 230
    AAN Head Required
    Whilst replacing the exhaust manifold, the usual sheared screws were found. Whilst easy-out'ing one of said screws, it was discovered that previous poking had drilled through to an oil gallery lying horizontally further in the head.
    Can anyone advise where I can source a replacement head. Are any other heads compatible? (ABY/ADU etc). Can anyone advise which oil gallery is likely to be running behind the exhaust manifold screws? I am keen to understand how it could affect the turbo?
    By the way - this is my first post so I'd just like to say Hi to the community!
  • Acidburn
    • 13459
    pm a user on here called spink he has one or two lying around.
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      i also have and adu and a aan head lying around.both have cracks adu>aan but i have been told they are repairable
      i dont know how much the shipping to the UK from Greece would be..i got the one from germany for 100euros shipping..so it would probably be the same i guess...
      • Flat on my back
        • Jan 2007
        • 2449
        Carefully drill the hole into the oil gallery to a known size, then fit an alloy plug.
        Its probably for the cam bearing caps oil feed...
        Carlos.
