RS2 vs S2 cambelt
  • audiman
    • 4827
    RS2 vs S2 cambelt
    I seem to remember a discussion ages ago (maybe on old forum) about the differences between the rs2 and s2 belt. From memory, you have to use rs2 belt if you are using rs2 water pump. IF you use S2 belt with rs2 water pump, doesnt the timing go out after a while???
    Had a quick search but couldnt find anything about it.
    Im sure someone here will able to tell me.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    RS2 water pump has a few less teeth on it so is smaller diameter. I assume (as I never checked when I fitted it) that the RS2 item is shorter to take up the difference between S2 and RS2 WP pulleys and so allow correct use of the tensioner. I don't see why the timing would alter at all unless the tensioner was on the limit and so it slipped. This would be fairly
    • audiman
      • 4827
      i have a feeling one of the belts is different by 1 tooth, but cant remember which way round it is? and i cant see why 1 tooth would make that much difference on the tensioner??
      i might be wrong, thats why im asking
      Audi UR Quattro
        Yeah, RS2 would be shorter. 1 Tooth could make a fair bit of difference, Audi wouldn't have made our lives more complicated for no reason now would they...
        • Audi_CQ
          • 940
          • Country: Norway
          RS2(ADU) = 150 teeth
          S2/S4(ABY/AAN) = 151
          3B / 7A = 147
          • Bram
            • Aug 2006
            • 2582
            correct. 1 tooth difference. The timing wil stay the same when you use a different timing belt as the individual tooth distances remains the same. When one tooth passes the crank pulley it will also turns the camwheel by 1 tooth.
            • Audi_CQ
              • 940
              • Country: Norway
              BTW: the RS2 belt fits perfect when building a tall block 2.5 with 3B type adjustable waterpump.
              • MidnightBlueS2
                • Jul 2005
                • 1653
                • Home: United States Current: Belgium
                Midnight Blue S2 - SOLD - 1993 S2 Avant
                • AndyP
                  • 6049
                  Cool, thanks for that
                  • Billman
                    • 4129
                    How is this WP adjustable? Does the 3B has a tensioner?
                    Go Holset or Go RS4
                      The waterpump is the tensioner on a 3B engine.
