Does anyone use the GT3076R on their AAN?
  • A80Avant
    • 10873
    • Country: Greece
    #31
    since you have the AAN engine,you dont really need the inlet manifold.Your plans seem fine.Get the cyl head ported,get the exhaust manifold with the T3 flange,turbo choice is spot on,and a bigger throttle valve will not make a difference all that much,but you could try it.Surging is caused by the turbo and the size of the throttle body will not affect it all that much.
    As for intercoolers,get a good one and dont forget to get an uprated clutch kit.You will definitelly need it!!
    • URSIMPO
      • Jul 2008
      • 431
      I have on order the 034 intercooler, it looks like the same kit as what Apikol is offering. I have already received my sachs pressure plate with organic cluth disc. I also have a aluminium flywheel, but after reading on this forum, people have had bad experience with ally flywheels on their s6. I will still use one however. if its too bad then i will stick the dual masss back on. Only thing is, my bottom end is being balanced, so putting the old flywheel on will throw the whole thing out.
      • GT500
        • Jun 2006
        • 2181
        Get your dual mass balanced at the same time, easy.
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • URSIMPO
          • Jul 2008
          • 431
          makes sense! at least i dont have to get the dm flywheel skimmed.
          • quattro20v
            • Jul 2007
            • 173
            Hope the intercooler fits under euro bumper.
            Now quattro less, my urs4 stolen 13.8
            • URSIMPO
              • Jul 2008
              • 431
              That has crossed my mind. I either have to trim the metal crash bar, or by a RS4 style bumper. I really dont want to start changing the look of the car, other wise a big ally wing and graphics might follow lol
              • URSIMPO
                • Jul 2008
                • 431
                Can the standard sparks be used, or do I need to uprate them at 450-500hp?
                • A80Avant
                  • 10873
                  • Country: Greece
                  #38
                  yes bosch ones F5D0PR or something are the ones to use.
                  • merlin's S4
                    • Jan 2005
                    • 1539
                    The Apikol IC is a great bit of kit but is 3.5inches thick and I'm certain it won't fit behind the stock bumper. You may stand a chance without the aircon rad. See this thread, this core was 3" thick and a lot of trimming was required! http://audifans.net/modules.php?name...ht=intercooler
                    • URSIMPO
                      • Jul 2008
                      • 431
                      there is this front bumper that i can purchase. If I did then I would have to diguise the fact that it had an intercooler and NO, I wouldn't use the mesh
                      http://cgi.ebay.co.uk/AUDI-S4-S6-FRO...3286.m20.l1116
                      I guess I can ask 034 to see if the can suppply a thinner intercooler first of though. Otherwise, as the tree said to the lumberjack "I'm stumped!"
