engine cut out @ high speed
  • topsparky
    • Oct 2005
    • 2014
    as above had a blast on the old private test track and @ 140 plus engine died ,did this twice and will not start again until you stop and leave it for a while
    then it starts ok and will cruise allday long @ 100
    any ideas chaps
    all input gratefully recieved
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
  • Knight Rider S4
    • 3541
    Fuel pump/relay?..have you vag.com'd the car?
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • AndyP
      • 6049
      If you bring it round tomorrow I'll VagCom it if you want.
      • quattro20v
        • Jul 2007
        • 173
        Hall sender? If it does this again try to poor some cold water behind the t-belt plastic cover.
        Now quattro less, my urs4 stolen 13.8
        • andyg plym
          • Nov 2006
          • 4646
          had the same on my old 10valve. turned out to be the lambda overheating. the car would not start when hot...
          • topsparky
            • Oct 2005
            • 2014
            thanks for the possible solutions guys
            @ andyp can i bring the car round monday night if poss mate
            1. SHORT SHIFT KIT
            3. H & R SPRINGS
            4. BILSTEIN SHOXS
            8. fmic fitted
            • topsparky
              • Oct 2005
              • 2014
              right then chaps
              have been to andyp's house and had it vag-com'd
              and this fault appeared
              00532- supply voltage b+ 27-10
              implausible signal intermitant
              anybody know the cause chaps
              1. SHORT SHIFT KIT
              3. H & R SPRINGS
              4. BILSTEIN SHOXS
              8. fmic fitted
              • quattro20v
                • Jul 2007
                • 173
                2234 (Blink Fault Code), 00532 VAG1551/2 Fault Code Number
                Supply Voltage Problem, ECU (J220) supply voltage too low or too high
                Poor ECU ground connection at intake manifold, battery discharged, check battery current drain with engine off
                Taken from SMJ web page.
                • topsparky
                  • Oct 2005
                  • 2014
                  cheers mate will have a look tomorrow
                  1. SHORT SHIFT KIT
                  3. H & R SPRINGS
                  4. BILSTEIN SHOXS
                  8. fmic fitted
                  • topsparky
                    • Oct 2005
                    • 2014
                    quick up date looks like my lambda if fubarred
                    has been on diagnostic equipment @ quattronics
                    and there is no change in the reading
                    so going to order a new one from vag parts
                    thanks for all your input fellas
                    1. SHORT SHIFT KIT
                    3. H & R SPRINGS
                    4. BILSTEIN SHOXS
                    8. fmic fitted
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      I doubt it was the lambda causing the problem, unless you were doing 140+ on part throttle.
                      SS
                      • volcano rs
                        • Jun 2005
                        • 2265
                        Originally posted by topsparky
                        right then chaps
                        and i thought you was a electrician
                        • topsparky
                          • Oct 2005
                          • 2014
                          i am
                          do i tell you how to post letters
                          stumpy
                          how you doing mate
                          1. SHORT SHIFT KIT
                          3. H & R SPRINGS
                          4. BILSTEIN SHOXS
                          8. fmic fitted
