RS2 Cam...
  • rjga20
    • 50
    • Country: Portugal
    RS2 Cam...
    Today I've bougth a supose RS2 cams how can I see if the cams are really RS2 cams??Here I see the numbers??or reference??Only numbers I can see was: 034 102 G; 034 AM.
  • Nuvo
    • Nov 2003
    • 3825
    The exhuast cam should read 034 109 022 G, the intake should be 034 109 021 AN.
    • rjga20
      • 50
      • Country: Portugal
      Yes I know but here is this numbers in the cam????
        AFAIK, the RS2 intake cam is the same as the AAN (and ABY?). Also the RS2 exhaust cam had two letters, an early one, "F" and a later one, "G". If you go into ETKA under Part Number with 034 109 022 F, you will find that after 30/09/97, "G" is the correct letter.
        • rjga20
          • 50
          • Country: Portugal
          Hi
          I've ETKA but I can't see here is the part number in the cam...I only whant to know if this cams was RS2 cam, here i can see it??Because I don't find the part number!
          • ur-s4315
            • 102
            My RS2 has these numbers on the camshafts EX: Mon5...9258...95H IN: 034AM but I'm not sure if the exhaust is the right one. I've measured the lift of the exhaust and it is 9,5mm.
            • mcandmar
              • Apr 2004
              • 5118
              Numbers on the cams dont fully match the part number in ETKA, 034 102 F or G on the cam sounds right. As above measure the lift to verify.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
