3bar MAP solutions
  • OrMar
    • May 2007
    • 132
    • Country: Croatia
    3bar MAP solutions
    Which one would work better in a RS2-ed 3b:
    1) Motorola 400 kPa sensor
    Tiny, custom domain, branded, url shortener, edit URL redirect, tinylink
    2) original 3B 2bar bosch sensor recalibrated to 3bar, by MB
    Anyone tried any of these ?
    They guy who sell Motorola says it is a straight swap. Is it really so easy ?
    Thank you,
    Mario
  • quattro20v
    • Jul 2007
    • 173
    I have the motorola map in my urs, no problems and a straight swap.
    Now quattro less, my urs4 stolen 13.8
    • OrMar
      • May 2007
      • 132
      • Country: Croatia
      Bought it from above or some other source ?
      So it's all the same for Motronic if there is Motorola or Bosch sensor?
      Just to clarify how that stuff works, do (for example) Bosch 2bar and Bosch 3bar sensors give same voltage for given pressure (say, 1 bar) ?
      Thanks,
      Mario
      • Knight Rider S4
        • 3541
        Good write up here on boost sensors and values
        search under ecu then manifold boost sensor
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Info on G71.
          SS
          • quattro20v
            • Jul 2007
            • 173
            Yes i bought from the same seller, will need to have a chip for the ecu that is made for 3bar map.
            • OrMar
              • May 2007
              • 132
              • Country: Croatia
              Thanks, guys it's everything there.
              So, basicaly, I can't use software writen for 2.5bar MAP with 3bar MAP, and that's what interested me.
              Mario
              • Bram
                • Aug 2006
                • 2582
                Thank you,
                Mario
                I would like to warn you to do business with MB Cartuning in Germany. A friend of mine shipped several Bosch MAP sensors to MB to get them re-calibrated. He paid 80 Euro for each of the sensors, the sensors were received by MB, but they never returned from MB-Cartuning. MB Cartuning has no customers help service in place, and not willing to investigate the problem, so you are really ****ed
                • OrMar
                  • May 2007
                  • 132
                  • Country: Croatia
                  I have send them a mail 2 weeks ago, and never got any answer. After your warning, I will definitely stay away from them, thank you.
                  Any other shop doing MAP recalibration ?
                  Mario
                  • S2_Dave
                    • Aug 2005
                    • 456
                    Minhea can do it.
                    David
                    '91 3B S2 Coupe
                    • OrMar
                      • May 2007
                      • 132
                      • Country: Croatia
                      OK, just to straigten things up:
                      To us "RS2" software made for 3bar Bosch sensor, I need 300 kpa MAP, like this one:
                      http://tinyurl.com/5a88mw
                      Thanks, OrMar
                      • Jonas_R
                        • 3780
                        • Country: Denmark
                        Vmap would be an alternative
                        Sleeper S2 Avant +450
                        A6 Avant 2.7t Stage 3
                        Audi S2 Coupe RS2'ed
                          http://tinyurl.com/5a88mw Thanks, OrMar
                          That link does NOT show a 3 bar Bosch Sensor. Here is a photo from SJM Autotechnik (a great 20VT 3B and AAN website):
                          • Jonas_R
                            • 3780
                            • Country: Denmark
                            However I actually have one of these 3 bar mapsensors in my car, and it works fine no problems at all. http://tinyurl.com/5a88mw
                              What is it? Based on a dilithium crystal? (I have a VMAP with the external toe-tapping adjustment option)
