Any BTDTs?
Perpetually trying to convert a B4 Coupe Quattro to an ersatz S2 here in the USA.
My plans over time changed from using an S2/200q20v ECU and two piece S2 3B ECU loom on a 3b to using AAN ECU for engine management as a stepping stone to VEMS standalone.
To make the loom install easier, I wanted to know whether its possible or if anyone has modified the S2 3b Loom/ECU harness to work with the AAN...I plan on using the 3B Distributor Hall Sensor for the cam timing...
Or should I just use an AAN loom...
Thank you much!
Thank you much!
