What injectors to use
  • prj
    • Mar 2010
    • 6308
    Get bigger than 441cc...
    And yes, those specs should be okay, 441cc are Ford Motorsport injectors.
    You can try 630cc dekas. Worst case - we'll run them with 3 bar fuel pressure.
    • Thuppu
      • 4115
      Is't Deka 630cc at 3 bar?
      How about BOSCH 52LB EV14 550cc/3bar, 630cc/4bar..?
      • prj
        • Mar 2010
        • 6308
        Yes, those 550cc@3bar should work with a 4 bar fpr.
        EDIT:
        Just make sure injector latency data is available for them.
        • Thuppu
          • 4115
          Really difficult to find data of these Bosch EV14 injectors. But seems to be 12 Ohms(12.8-14.5 Ohms). Part number 0280158117.
          • prj
            • Mar 2010
            • 6308
            Uhm...
            Yes?
            Buy them, that's all the data one could ever need.
            • Thuppu
              • 4115
              Haha, you found data. I was also looking at the boschdealer site but didn't find anything, maybe I should put my glasses on...
              So, what does the data tell you?
                Originally posted by prj
                The 550cc EV14 will be fine.
                But the 750cc - I don't think motronic has enough resolution for that to run at idle.
                whats the minimium motronics can run, I have these injectors and they idle perfectly a 2 ms pulse width
                • prj
                  • Mar 2010
                  • 6308
                  2ms?
                  Stock 280cc injector idle is around 2ms.
                  Or are you taking in account injector lag time as well with that pulsewidth?
                  It tells me injector latency at 4 bar for example, which is needed so that low pulsewidths work fine and the ECU injects as much fuel as it thinks it is injecting.
                    That includes injector lag time, remember I have VEMS. I have seen these used on motronics also I can't see why there would be a problem these injectors work down to 0.8ms
                    • prj
                      • Mar 2010
                      • 6308
                      Which are "these"?
                      550cc will be fine.
                      630cc at 3 bar also afaik, above that porkkis can chime in on what problems he met if he likes.
                      It might be of course that we don't know what to change in Motronic to accept bigger injectors.
                      But even then, how far do you really want to go on the stock ECU? Anything much over 500 hp without antilag is quite useless.
                      • Thuppu
                        • 4115
                        The 750cc seems to have same part number(same data).
                        0280158117-750
                        0280158117-550
                        • prj
                          • Mar 2010
                          • 6308
                          0280158117-750
                          0280158117-550
                          I do not think this is possible unless someone milled the injectors.
                          Different flow will have different part number from the factory.
                          • Thuppu
                            • 4115
                            Same electrical data?
                            • prj
                              • Mar 2010
                              • 6308
                              I would hazard a guess that your info is just wrong...
                              • Thuppu
                                • 4115
                                Yea, I don't know..? Same injector only bigger "bore"?
                                0280158117 (550)
                                0280158117-650
                                0280158117-750
                                0280158117-1000
