Some of you already know, but I've been having a custom oil catch tank designed for my S2. Well it's finished
I wanted to get a baffled tank as they are recognised to be the most efficicent at separating oil vapour.
Here it is:
[front view]
The body of the tank is 3" diameter alloy tube. The outlets are ¾". There are four outlets on the tank. 2 for PCV connections to the head and block. One for clean air outlet to the inner wing and one for the drain back to the sump.
The capacity is 0.75 litres (It's the same size as one used for 500bhp RS Cosworths) so should be sufficient
[top view]
[bottom view]
[rear view] showing bracket
Another thing I wanted was to make it easy to fit. On the rear are two parallel plates that fit above and below the strut brace. The plates are drilled so nuts and bolts can be used to clamp it in place. (it will need some foam to pack it out and stop any rattles)
Here it is in position, I've not fitted it properly yet as I need to get an adaptor made to fit the breather on the block. I'll also need to do some creative plumbing to make it all fit neatly but so far so good.
[in situ]
As for the price. A steal at £80 + £6.95 P&P
If anyone want's one I can supply you the email address or phone number of the chap who made it. He's happy to make more of them. He's very busy though so try not to swamp him. We've been back and forthing over the design since January but he knocked up the finished job in about two weeks.
Ben
Here it is:
[front view]
[top view]
[bottom view]
[in situ]
Ben
