Advice an options for my next upgrade - suggestions please
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    just to add,that for a car using stock dual mass flywheels with different rods+pistons,if the rods are not off,then there is no need to rebalance for a car that wont go above 600hp.Again PKmotorsport has built a 650hp S2 without needing balancing.
    I didnt balance mahle pistons and scat rods with stock crank and flywheel.Car is running smoothly
    • s2bug
      • Nov 2007
      • 484
      Originally posted by Jamo
      I'd forget the turbo upgrade until you've seen the state of the engine if your fitting new rods. If your block needs to be rebored then thats £500 for pistons alone
      You also need to factor in £250-300 for balancing the rod and crank and that again if you need a rebore for the large pistons.
      For you budget keep it simple get the basic in place and then add the cherry on top last i.e the turbo.
      I'm not sold on vems for a sub 500 bhp car one remap should sort it and it's fit and forget. One MRC remap and it's over, the thing with aftermarket ecu's are they are great but you have to spend time getting it right.
      Let me break it down for you like this
      S2avant, stock bottom end ( to my knowledge ) 3 inch exhaust, RS2 turbo, RS2 manifold, RS2 injectors, RS2 intercooler and MRC Generic high boost chips
      0-60 in 4 seconds
      12.8 1/4 mile time
      You can get the performance without buying the best bits of the shelf.
      This was the route I was going and I was told by everyone that had done it the RS2 route is fun and practical.
      But I sold it all and have gone for a spec a touch above yours and it's hassle.
      Less hassle = more driving time.
      Sounds like reasonale buck + RS2 upgrade that is about 350 bhp = as you say fun and drive time ...
      then if the need is great then go for the skats and GT3071?
      Splendid
      Thanks Jamo
      S2 Avant ABY
      • terrybullwon
        • Mar 2006
        • 8782
        I know of a bolt on RS2 set up thats going...
        Have you spoken to Joe @ axismotor sports yet to see if he can help you?
        Chef
        • terrybullwon
          • Mar 2006
          • 8782
          Oh and Corey is building my manifold and exhaust.
          Chef
          • s2bug
            • Nov 2007
            • 484
            fanatastic will give him a shout.
            Many thanks for the heads up
            S2 Avant ABY
