There ain't much difference between a 3071r.82 and a 3076r.63
What makes the 3071 a good turbo is it's super quick spool with a 3 inch downpipe. A .82r would put what 400-500 rpm on that spool?
My advice if you have a 3071 already try the larger hotside, if buying from new buy 3076r then you can upgrade to .82 and 500 plus bhp without changing turbo.
They share the same hotsides so they would be interchangeable.
