A little bit of MRC magic.
    I think TerryB's worked out cheaper than that but not much, it's a combo gauge for both.
      I'm sure MRC wouldn't sell chips running high EGT's, this is the same chipset S2Avant is running does he have any EGT logs?
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Paul must know what Matt's like. That's given him something to worry about.
        It never hurts to have a few gauges to know what's going on with your engine.
        SS
        • MattS2
          • Apr 2006
          • 657
          Ben doesn't have an EGT gauge so no logs unfortunately.
          Ex owner of a 1993 Silver Avant - RS2 spec.
          2002 A8 sport 2.8 quattro Sold
          2003 A6 Avant Tdi
          Mk Indy 2.0 pinto circa 160 Bhp
          2004 VW Caddy SDi
          2002 Civic Type R
            Take it for a thrash and then immediately look to see if the EM is glowing
            • MidnightBlueS2
              • Jul 2005
              • 1653
              • Home: United States Current: Belgium
              #21
              Originally posted by shark_90
              Up to 1.9 then dropping off to 1.5...
              MRC rule !!!!
              Now, I'm probably going to sound like I'm speaking nonsense BUT Doug and Mihnea mapped my Avant a few years ago ( car still pulling very strong, ate up and left an SLK 350 for dead just a few days ago ) and it will peak at 1.9 but no backing off of the boost pressure if I stay at WOT, it just keeps it at 1.9 till 7000 rpm....
              Is this because I have a larger turbo that can keep up with revs ?
              Midnight Blue S2 - SOLD - 1993 S2 Avant
                Yes
                • BrianSmith_S2
                  • Jun 2005
                  • 1342
                  • Home: Northern Ireland Current: British Antarctic Territory
                  #23
                  Originally posted by Andy_Casey
                  Yes
                  what turbo is being used?
                  • MidnightBlueS2
                    • Jul 2005
                    • 1653
                    #24
                    Hybrid Turbo K26/K27/K29 courteousy of Doug.
                    IIRC, it's the same one that he had in his coupé when he pulled a 3.6 sec 0-100km/h run.
                    Mihnea actually mapped it below it's peak performance or it would've bent my stock rods...
                    Even at WOT and full torque, you can just hear it whirring effortlessly. It really could be pushing more...
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      and what is it producing? + what is the lag?
                      • MidnightBlueS2
                        • Jul 2005
                        • 1653
                        #26
                        400hp - 500Nm... officially :mischeif:
                        Full boost at 3500rpm.
                        It could produce more but my main goal when going for this power upgrade was RELIABILITY !
                        Doug & Mihnea promised that and that's what I got.
                        Seriously, I live in an area where S2's - RS2's are virtually unheard of. Hardly anyone has any experience working on them... MRC, once back home, would be over 500km away plus the english channel to cross.
                        I wanted, heck belay that, I NEEDED to play safe.
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #27
                          niiice.
                          thing is that i thought that turbo was able for much more with 1.9bar of boost all the way...It is supposed to be able for 500hp!
                          Anyway,nice and reliable is never bad!
                          • MidnightBlueS2
                            • Jul 2005
                            • 1653
                            #28
                            niiice.
                            Thanx !
                            500hp can be achieved but as mentioned earlier, it would've bent my rods... Not the turbo's fault, just sensible and protective mapping.
                              I'm running a Mihnea map on my RS2 setup , peaks at almost 2 Bar on the gauge and falls to 1.5, at the moment its restricted by the 3B downpipe but theres a 3" 034 system sitting in the garage waiting
                              3071 will be here soon..
                              • DJones
                                • Jun 2005
                                • 2020
                                It will be like a different car!!! hope you've done your rods..
