I dont have a pic to hand but can anyone tell me which POS does cyl 5 run off?
Looking from the front, the one on the left or the one at 90 degrees to it on the right?
Looking from the front, the one on the left or the one at 90 degrees to it on the right? thanks
The one with only two wires coming out of the three pin connector end.
Mine are on the other side of the engine bay, on an L shaped bracket.
I have an intermittent misfire on No 5, happening about 90% of the time the car is running, i thought it was the coil (have another on its way to me)
The other day i tried to swap the POS's around to see if the misfire moves to another cylinder, but the cables from one were not long enough. So i plugged everything back as it was, now the misfire still happens but nowhere near as much, maybe 50% of the time now.
