Which POS for cyl 5 on AAN?
  • martinjs
    • 3205
    I dont have a pic to hand but can anyone tell me which POS does cyl 5 run off?
    Looking from the front, the one on the left or the one at 90 degrees to it on the right?
    thanks
  • Knight Rider S4
    • 3541
    Scroll down and all the info there
    Steve
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Jas11n
      • 5067
      One on the left I think Martin.
      Check SJM site ►►► Linky
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • Jas11n
        • 5067
        You had your weetabix Steve?
        • Knight Rider S4
          • 3541
          This a rare feeling beating you to it...
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
            Looking from the front, the one on the left or the one at 90 degrees to it on the right? thanks
            The one with only two wires coming out of the three pin connector end.
            • martinjs
              • 3205
              Ok, thanks all.
                Ok, thanks all.
                Suggest you follow this lead down the rabbit hole (you will find info about swapping pins):
                http://forums.audiworld.com/s4s6/msgs/149771.phtml
                • martinjs
                  • 3205
                  Mine are on the other side of the engine bay, on an L shaped bracket.
                  I have an intermittent misfire on No 5, happening about 90% of the time the car is running, i thought it was the coil (have another on its way to me)
                  The other day i tried to swap the POS's around to see if the misfire moves to another cylinder, but the cables from one were not long enough. So i plugged everything back as it was, now the misfire still happens but nowhere near as much, maybe 50% of the time now.
                  • wilywyg
                    • Sep 2008
                    • 94
                    I have just had the same
                    i have just posted a thread today http://www.s2forum.com/forum/showthr...&highlight=pos
                    i hope this can help you.
                    Paul
                    LIFE WILL NEVER BE THE SAME
                    • martinjs
                      • 3205
                      It got sorted Paul, i used a V6 POS for a while then replaced with an OE one.
                      • wilywyg
                        • Sep 2008
                        • 94
                        what did you do with the old one
                        just wondering if its worth looking at for a repair
                        i repaired mine, for the cost of postage??
                        Paul
                        • martinjs
                          • 3205
                          Binned it.
