I've seen a few adjustable cam wheels (cambelt) but are any of them hall sensor friendly? Most 034 stuff says it requires a 3B dizzy style hall sensor fitting... linky.
Adjustable cam wheel - hall sensor friendly
Dahlback I think - not 100% sure though ... ??????Paul Nugent
There's the Dahlbäck Racing one.
Which sounds quite impressive, seeing as the original looks like it's made from recycled chinese biscuit tins.Originally posted by Dahlbäck RacingAdjustable cam gears, 50% lighter than stock gear.SSComment
Dahlback also do the adjustable cam-gear sprocket so that you can alter the timing separetely on the cams... If you wish to go there - not cheap nor hassle free - setting those up would be tiresome, but the adjustable cam pulley advances/retards the timing of BOTH cams wrt the crankshaft.Paul Nugent
I like the Dahlback stuff on the face of things - some top gear on there like a dry sump system now and an electrical pump for the hydraulics - both of which reduce drag on the engine - but some scarey big prices in there...Paul Nugent
Hmm...
Tempting them, as I'm not sure I trust that stock ABY one, although I'm sure lots of people do.
The other option is to fit a 3B inlet cam, distributor and hall sender. You can fit a cheaper 3B front pulley then.
I may have a 3B distrubutor for sale, to help fund a DBR pulley.
The wider belt option is 31mm BTW.SSComment
They list the 21mm item twice, I'm not that daft
Attached FilesCheers'en, AndyC
Adjustable cam wheel from www.tbc-shop.com
It's the same as dahlbäcks, no new hall sensor required.Comment
I can't see it listed twice.Attached FilesSSComment
