How long to remove and fit an S2 engine
    For those that have done it before, how long does it realistically take to remove and refit an engine into an S2?
  • johne
    • Apr 2007
    • 1405
    Jamo,
    I've done it twice and I'd say 10 hours minimum but a lot depends on your facilities, is the car on a hoist or ramps etc. and then there's just no knowing how long some of Audi's design features such as one nicely concealed turbo flange bolt with a specially sized 16mm nut on a m10 stud (which you'd expect to have a 17mm nut as the other 2 are) just so they can squeeze it in will take to undo.
    Like lots of things in life, it depends how good your tools are.............
    John
    • Rusty
      • 18953
      I think it depends how much of that plastic crap there is under the bonnet. As I've removed mine I can have just about all of the ancillaries out in an hour or two. If you have to work around all the plastic then indeed 10 hours is a conservative estimate.
      • johne
        • Apr 2007
        • 1405
        Just to clarify, I meant out and back in in 10 hours.
        John
        • terrybullwon
          • Mar 2006
          • 8782
          1 day tp get engine out and head off.
          Chef
            When the engine has been removed are you talking head off, block removed or all in one go?
            • 20Vcqdriver
              • 829
              time...
              Three 8 hour days+ and using just drive on ramps. Also mine is a series 2 so no front panel that can be removed that meant engine went in from above almost vertical.
              1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
              2004 A4 2.5TDi convertible, re-mapped to 180bhp
              2011 A5 sportback 3TDi-Backbox delete, remap
              • Fat Audi 80
                • 10547
                I would double those estimates Jamo.
                The Perfectionist
                  Cheers Fatty
                  • s2driveruk
                    • 12696
                    as someone who had never removed one before...ever - took me at least a day to remove (being careful, labeling and photos as i went and at least as much to get back in and all the bits back on.....with a helping hand from Pete too.
                    I think you could do it much quicker but I wanted everything to be spot on so took as much time as I felt comfortable with.
                    If you haven't got the right tools, then it will be a really frustrating task and that is no understatement Be prepared for siezed stuff and usual bits you can't get a socket or spanner on etc.
                    HTH
                    David
                    1992 3b S2 Coupe
                      I think Johne's quote is only valid if you've done it before and have immediate access to a mighty toolkit along with good hoists and such... and there are no showstopping issues with seized bolts etc - those can really set you back.
                      I'd say most of us would do well to get the engine out in ~8hrs
                      Then any sort of time invested in cleanup or maintenance of the engine bay --> inspecting the loom, aircon pipes, steering, brake pipes
                      And realistically its probably another 8hrs getting it back in working alone... This from hazy memories of taking a KV engine in / out of the old Typ85 - similar task on the big scheme of things.
                      • Acidburn
                        • 13459
                        HTH
                        David
                        Yup, i'd hazard a guess at a day to remove and a day to put one back in providing you know exactly what goes where and work non stop.
                        One thing that catches people out is the gearbox bolts as there's a couple that WILL be covered in grease and I doubt you'd be able to get to unless you know they are there.
                        Downpipe /turbo nuts are a pita as me and david found out.
                        @david, i'll give you a shout when mines removed/put back in
                        • s2driveruk
                          • 12696
                          remember to factor in at least 20 minutes to try electrocuting yourself on the starter when you plg one lead into the wrong terminal then try messing with it
                          1992 3b S2 Coupe
                            Oh I hate that - did it once - disconnecting both sides of battery is the way forward when tampering with the old starter.
                            • s2driveruk
                              • 12696
                              or do a Pete and stick a screwdriver in to check its getting a feed while you crank it still remember the sparks
                              1992 3b S2 Coupe
