FYI for anybody fitting a new oil pump
  • mcandmar
    • Apr 2004
    • 5118
    Rebuild it first! I found a load of fine grit inside mine last night
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    You found fine grit in the NEW one ?
    • mcandmar
      • Apr 2004
      • 5118
      Yep, not what i was expecting to find at all. I will post a pic tonight to show you what i mean.
      Mark.
        Wtf!!!
          Jees Mark - lucky you went investigating - I assume there was some grit on the external surface that tipped you off... You could easily have destroyed an engine with that and had no proof that the grit came from a new component - you would just be blamed for general uncleanliness during the build. Nightmare - but well done for spotting it... Always amazes me just how often (myself included) you just assume a new part should be 100% OK...
            Hmm I'm sure someone else S2 failed recently after fitting a new oil pump, coincident?
            • terrybullwon
              • Mar 2006
              • 8782
              Mine was Clean, I took it apart to fit the diamond drive. I have a spare drive if one wants it?
              Chef
                Drive is now sold
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  wassa diamond drive when it is at home?
                  Oh hold on, I thought it would be a functional upgrade but as Jamilionaire bought it, it must just be worthless bling
                  Cheers n
                  Si
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                  • shark_90
                    • 1475
                    Jamillionaire.. ha! Brilliant!
                    1994 Audi S2 Avant - in pieces
                    2006 Skoda Octavia vRS 2.0TFSi - goes fast
                    1985 Audi 90 quattro - is wet
                    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
                      I haven't bought the ICE drive, James has, it allows the pump to rev higher and not slip at higher revs maintaining oil pressure.
                      Think Terrybullwon is going for a high redline
                        Omg !
                        Well spotted. Could have been a mega PITA.
                        So you're making progress? If I can be of any assistance, just phone me and I'd be happy to return the favour.
                        Kind regards.
                        • GazzaG60
                          • 4133
                          my new oil pump would not fit properly. it seeped oil from the edges, i also had to file down a few bits to fit the pulley guard back on.
                          made in korea stamped on it.
                          • HPmuirt
                            S2Forum April Fool
                            • Apr 2005
                            • 3014
                            Ah OK cheers Jamo, that IS interesting
                            Are there any thoughts on fitting them on road/occasional track cars? i.e. is it worth while whilst you're in there or should you stick with OEM? Are they big bucks for little gain or a sensible mod?
                            Cheers n
                            Si
                              No point for a standard car IMO
