wideband lambda
  • QuattroFever
    • May 2006
    • 1360
    wideband lambda
    about time i replaced my lambda sensor but i have been recommended to get a wideband from innovate motorsport. Can the motronic adapt to the signal from a wideband. Im going to use the extra signal to monitor air/fuel to make diagnostics easier. If performance/fuel economy is improved then thatll be a bonus.
    Volcano ABY coupe
    Ant
    No the ECU input is narrow band only.
    • ranz
      • May 2006
      • 119
      I don't know about innovate motorsport wideband but vems wideband has NB output, so the signal is not coming directli from lambda but from the gauge (i have the same system and installed it to many 20VT-s, works fine).
      • GazzaG60
        • 4133
        innovate has NB out too. its not the best though. use 2 probes is best.
        some ecu's have trouble with the sampling speeds of the output.
        the new LM2 looks nice. i prefer the vems gauge though. nice fit, size and suits the pod in the vent.
        • EspenW
          • Apr 2007
          • 1534
          • Country: Norway
          Innovate LC-1 has two analog outputs. Either can be programmed to simulate a narrowband. On my K-Jet Lambda Golf, I have programmed for 15.3 at cruise and 12.6 at WOT, giving me closed loop feedback at all loads, ideal when runnning E85 (and various mixes of E85 and petrol)
          On the RS2, I'm still using the stock narrowband to feed the ECU, and use the wideband (placed right in front of one of the cats) to monitor AFR for tuning.
          1994 80E Avant
          1986 2L Golf 2 on Alcohol
            I've just had a second Lambada flange welded into the DP so I can run a separate WBO2 and leave the OE narrowband to do it's thing... Slightly more expensive (!) but th Moronic gets what it needs that way.
            • slow2
              • Apr 2004
              • 238
              I've been using the bosch LSU4 lambda probe, it has narrow band feed for motronic,
              and WBO2 feed for my zietronix's A/F meter. Used them for the last 3 years.
              Dez
              Never did overtime until i purchased........s2
                Aha a bosch solution, will look at this further, actually I remember your setup from the rolling road
                • GazzaG60
                  • 4133
                  LS4U is the stanard prope used for most WB02 setups. easy and cheap to find. LC/LM Zietronix and VEMS use them. id expect others too. its basically a mk4 1.8t probe IIRC
                    I've never understood why there are so many type of probes, for instance the Coupe & Avant / RS2 have different probes why is that?
                    Maybe for a different thread
                    PS LSU4 or LS4U these are two different parts apparently
                    LSU4 looks like the VEMS one http://www.phattransmissions.com/VEM...de/README.html
                    • GazzaG60
                      • 4133
                      it varies due to technology and time from what i gathered. a brief description of how i understand it. there are only really 3 types on NB probe. the universals are the same as the facory ones without the plug.
                      the first probes had no heat element so it took a while for the exhaust gas to heat them to a temperature where they could return figures to the ecu.2 wire
                      the next lot were heat element based. this get you to probe control faster these are 3 wire.
                      the final type is the 4 wire with a secondary ground. not sure of the reasoning here other than to bulk out the weakest point in a 0-1v feedback which is resistance.
                      • ranz
                        • May 2006
                        • 119
                        But the LSU4 doe's not have NB output? or am I getting something wrong?
                        • GazzaG60
                          • 4133
                          is that the missing pin on the connector?
                          • QuattroFever
                            • May 2006
                            • 1360
                            so a wideband can be fitted to motronic but has no benefits over a narrowband other than being able to use an A/F gauge.
                            A wideband will still only see either stoich, rich or lean and no in between?
                            Volcano ABY coupe
                            Ant
                              Got it in one
