Homefries boost figures
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    I am sure there is a thread on this somewhere but I cannot find it.
    Just wanted to know what the maximum boost figures for each gear should be with a healthy homefried Aby
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    i see 20 to 23psi in all gears except 1st
    • johne
      • Apr 2007
      • 1405
      1.4 bar, 20 PSI in any gear unless limited by any of the protection mechanisms
        Yes there is, i have a thread posted up.
          there's a boost graph I posted in the gallery too. You shouldn't see any difference in boost other than 1st and maybe 2nd.
          • max_s2
            • Mar 2006
            • 498
            • Country: Latvia
            Stupid question: what's a homefrie?
            • nip
              • Apr 2006
              • 1786
              hi lv,max its a chip done by paul at s2 central , from standard 230bhp it takes it to approx 280, its well worth it
              • max_s2
                • Mar 2006
                • 498
                • Country: Latvia
                And how much EUR/GBP for it?
                Is it possible to add it myself to ECU?
                • nip
                  • Apr 2006
                  • 1786
                  you have to send ur ecu to ireland to paul, not sure how much it is mate
                    ABY Homefry boost / gear profile
                    1st: 0.4 bar
                    2nd: 1.2 bar
                    3rd: 1.4 bar dropping to 1-1.2 bar
                    4th: same as 3rd
                    5th same as 3rd
                    6th: same as 3rd
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      what are you doing waiting??? go for it,the car will be much more fast and fun like 1000 times
                        I think paul can also send you the chip but ideally you should send him your ecu as a socket needs to be welded into it.
                        • HPmuirt
                          S2Forum April Fool
                          • Apr 2005
                          • 3014
                          Welded?
                          I've gotta MIG welder, will that work or do I need a gas torch?
                          Cheers n
                          Si
                          Subtle mods here and there
                          2011 A5 3.0 TDi - Lava Grey
                            You do that mr Muirt, I'm sure your car will go faster as a result
                            • bertman
                              • Apr 2007
                              • 1173
                              1st: 0.4 bar
                              2nd: 1.2 bar
                              4th: same as 3rd
                              5th same as 3rd
                              6th: same as 3rd
                              http://www.s2forum.com/forum/showthread.php?t=10806
                              Cheers for the figures Jamo
                              What point in the rev range should you see a drop off in the boost?
                              Rob
