Hi
I have been experiencing signs of coolant leaking around the brass bleed screw. Discovered that the washer was completely corroded away. Seems like I may have overtightened
as there are now 2 cracks running away from the bleed screw.
Is there a remedy - even short term - or do I need to replace the rad?
Are the more robust aftermarket rads or will the oem do?
Thanks
as there are now 2 cracks running away from the bleed screw.Is there a remedy - even short term - or do I need to replace the rad?
Thanks
